cam tensioner
  • blink543
  • blink543's Avatar Topic Author
cam tensioner
21 Jun 2015 22:08
#677676
What happens if you rotate the engine at the timing plate without the tensioner keeping tension on the cam? Will the cam chain possibly be out of alignment now?
Adam james
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: cam tensioner
22 Jun 2015 06:24
#677700
The sprocket at the crank is very small. It could skip a tooth. Check your cam timing before going any further.
  • blink543
Re: cam tensioner
22 Jun 2015 07:20
#677711
Ok
Adam james
