valve adjustment
- mithrander
valve adjustment
20 Jun 2015 14:29
I am having trouble identifying the alignment marks for the intake cam that you align with the lip of the head prior to measuring the gap between the valve shim and the cam lobe. For the exhaust side they are clearly visible. Does anyone have any pics that might help me?
- missionkz
Re: valve adjustment
20 Jun 2015 14:36Well.... what bike model, engine and year? Etc etc.mithrander wrote: I am having trouble identifying the alignment marks for the intake cam that you align with the lip of the head prior to measuring the gap between the valve shim and the cam lobe. For the exhaust side they are clearly visible. Does anyone have any pics that might help me?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- mithrander
20 Jun 2015 16:13
The safest way is to have the cam pointing 180* away from the cam follower. I do it when the two cams are pointing away from each other. TDC for that cylinder, that way I can adjust both at the same time.
- missionkz
20 Jun 2015 18:14
I do it that way too but, I also have noticed there are spots on the lobe that have another .001" more clearance then when measured at 180degrees. I don't know why or if that just happens to be what happens to these cams after 2 and half billion revolutions.
Bruce
1977 KZ1000A1
1977 KZ1000A1
20 Jun 2015 18:58 - 20 Jun 2015 18:59
Loose cam bearing tolerances. I was taught setting them this way assures proper valve timing.
Last edit: 20 Jun 2015 18:59 by SWest.
- mithrander
21 Jun 2015 14:38 - 21 Jun 2015 14:41
So you place each cam lobe 180 from the follower then measure gap 1 at a time? I wanted to add a picture but I can't seem to do so
Last edit: 21 Jun 2015 14:41 by mithrander.
21 Jun 2015 14:44
I do it this way. One lobe pointing forward and the intake pointing aft. TDC for that cylinder.
- mithrander
21 Jun 2015 15:18
Just did it and that works fine. Exhaust clearances were the same as I measured using the maintain manual and now I have the intake values also. Thanks for the help. I need to order a few shims any recommendations?
21 Jun 2015 15:35
I've been getting my shims from jetsrus, Z1E may have them but seem to be out of stock often, you might try a local bike shop the just works on all brands. You may be able to trade plus $5.
- missionkz
21 Jun 2015 16:46
Make a list in the thread of what you have and what you need.
A lot of us have amassed a few over the years!
Bruce
1977 KZ1000A1
1977 KZ1000A1
- missionkz
21 Jun 2015 16:59 - 22 Jun 2015 10:44
dup
Bruce
1977 KZ1000A1
1977 KZ1000A1
Last edit: 22 Jun 2015 10:44 by missionkz. Reason: duplicate
