interchangable clutch plate kits for KZ750's?
- Special KK
19 Jun 2015 16:17
May need some replacement clutch plates for my kz750 H4 LTD four cylinder in near future. Cant fiind any in the UK that aren't stupid money or imports from the states, which again, are too pricey. Plenty of reasonably priced kz650 clutch kits on UK ebay though, will these fit the kz750 clutch basket anyone know?
Or any other Z/KZ models that have same clutch system that can be interchanged perhaps?
Cheers
Cheers
2008 Aprilia Shiver SL750
1983 Kawasaki KZ750 LTD H4 Four cylinder
Previous bikes:
1999 Honda CBR 600 fx
1992 Kawasaki Zephyr 550b
1990 Honda CG 125
"All work and no play makes jack a dull boy"
Previous bikes:
1990 Honda CG 125
- Tyrell Corp
Re: interchangable clutch plate kits for KZ750's?
19 Jun 2015 17:51
Silly cheap, saw it tonight, i was goung to have it.
- Special KK
20 Jun 2015 10:20
that is ridiculously cheap, only really need the friction plates though so dunno what kind of condition they may be in, could be junk? And would it fit my KZ 750 ltd?
Previous bikes:
1990 Honda CG 125
Previous bikes:
1990 Honda CG 125
- OnkelB
20 Jun 2015 10:50 - 20 Jun 2015 12:52
Yes, the 650 plates will work. The 650, 750 four (including GPz 750 and GPz 750 Turbo up to 1985), 900 and 1000 (pre J - engine) all use the same friction plates: 13088-030.
The J - engine models use part no. 13088-1013 - I suspect they may be the same, just a different number, but I'll have to check to say for sure.
Edit: Just went out and compared a 13088-030 to a 13088-1013 - they're NOT the same, 13088-1013 is larger and the ears are spaced differently.
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 20 Jun 2015 12:52 by OnkelB.
The following user(s) said Thank You: Special KK
- Special KK
20 Jun 2015 12:14
Awesome, should make it a lot easier to find a decently priced set in the UK now
Thanks a lot.
Previous bikes:
1990 Honda CG 125
Previous bikes:
1990 Honda CG 125
20 Jun 2015 12:19
Also be careful with the GPz 750 clutches. The later ones had a completely different engine (based on the water cooled 900Ninja), and probably have a very different clutch.
The following user(s) said Thank You: OnkelB
- Special KK
20 Jun 2015 12:50
Ok thanks ill bear that in mind when i shop around.
Previous bikes:
1990 Honda CG 125
Previous bikes:
1990 Honda CG 125
- OnkelB
20 Jun 2015 12:51
Good catch, Texas, thanks.
You're right, the GPZ 750 R (aka ZX 750 G) introduced in 1986 is a different engine altogether, based on the GPZ900R as you say - both use the same friction plates as the J - engines, 13088-1013.
