Where can I get clutch cable for KZ750E2?
- DanDan
16 Jun 2015 15:31
I baught this bike new, and even thouth it looks so-so, it runs great. My preasant problem is a broken clutch cable. Is there a place that I can get a new one. (KZ750E2) Thanks
- rstnick
Re: Where can I get clutch cable for KZ750E2?
16 Jun 2015 15:52
Here's a list of parts suppliers:
www.kz650.info/links.php?type=1
Z1Enterprises in New York I've used many times in the past.
Great service from them.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
16 Jun 2015 16:16
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationThere's a couple sellers on eBay I've been buying my cables from.
You might ask one of them for one that fits your model.
- RonKZ650
16 Jun 2015 19:47
You'll most likely have to buy a Motion Pro cable, as I doubt Kawasaki still supplies, but you may get lucky. The motion pro is not all that bad of cable. I've used them, and would rate them a 6 on a scale of 1 to 10 which is better than most aftermarket offerings, and motion pro is not the best quality company I've seen to say the least. The problem is they consolidate many cables into one, so the length will most likely be +/- a couple inches, diameter is less, and no spring down towards the exhaust to help keep from melting. You get what you can get any more though, and the motion pro is usable, which is more than I can say for most their stuff.
16 Jun 2015 21:23
I use to buy GL 1000 clutch cables. They were thicker and last longer. That was when I could compare off the shelf.
- davido
17 Jun 2015 11:13
Cables ('81 -'82 Kz750-e2/e3). Dont know where you live but here you go;
www.cmsnl.com/kawasaki-1981-kz750-e2_mod...st/9518.html#results
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
