GPz550 Oil Leak
  • mangosteen
  • mangosteen's Avatar Topic Author
GPz550 Oil Leak
15 Jun 2015 16:42
#676715
Hi all,
I just picked up an '83 GPz 550 with an '84 engine in it. It has a pretty ugly oil leak coming from what appears to be the gear shift shaft/rod(?) seal. The previous owner was 95% sure that this was the source of the leak. Before I tear into it- any tips, hints, or cautions I should know of?
I've read a bit about there being a risk of pulling the shaft out too far and having issues with something (not sure what) coming loose and dropping into no man's land. Any advice is very welcome and appreciated.
Thanks in advance...
1983 GPz 550
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: GPz550 Oil Leak
15 Jun 2015 16:58
#676717
Just fixed this on mine, the inner transmission cover comers off, under the outer casing.
Replace the oil seal on the gear shaft outer casing too - same part number, gives a really nice smooth gear shift.
(total misuse of an 'oil seal' but it works, cheaper than a bearing...kawasaki got 99% of their designs so right) )
  • mangosteen
Re: GPz550 Oil Leak
15 Jun 2015 17:04
#676718
Thanks, Tyrell. Any idea what that part number is?
1983 GPz 550
  • DSummerlin
  • DSummerlin's Avatar
Re: GPz550 Oil Leak
16 Jun 2015 21:59
#676908
Dude...
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
  • TexasKZ
  • TexasKZ's Avatar
  • Busy
Re: GPz550 Oil Leak
17 Jun 2015 04:50
#676911
  • TexasKZ
  • TexasKZ's Avatar
  • Busy
Re: GPz550 Oil Leak
17 Jun 2015 04:51
#676912
