GPZ 1100 UT 2 hole cam sprockets
- Mk2Rookie
15 Jun 2015 10:29
Hi! I got a good set of UT camshafts in good condition but never actually checked if i could get a set of adjustable cam sprockets to use with my J/b1/b2 crankshaft and hyvo chain. APE makes sprockets to for the J/GPZ engines to use 3 hole cams and 2 hole sprockets to use in the KZ engine. I found some Web Cam sprockets on the Webike site from japan for the same price as the cams but can't finde the sprockets on Web Cam's side.... What to do now ? Do i have to get a pair of 3 hole cams to be able to time the engine correctly ?
Any thoughts ?
Simon
Any thoughts ?
Simon
- gpz1170
Re: GPZ 1100 UT 2 hole cam sprockets
16 Jun 2015 17:59
Hi Simon
I just took my stock sprockets and slotted them. They work fine. If you can find someone with after market sprockets, just copy the slot for size.
don
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
- Mk2Rookie
21 Jun 2015 05:51
I don't have any slottet cam gears to messure from, any tricks to mark it out ? And how did you cut the slots ? Drill a hole on each side and the grind the rest ?
Simon
Simon
- gpz1170
23 Jun 2015 18:27
used a dremel with a burred bit the same size as the hole. elongated it about 1/8" on each side.
don
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
