Oil...
- KZPETE33
- 76 900 Constant thorn in my side....love it.
Oil...
14 Jun 2015 19:49
I've seen good thins from Castrol GTX 20-50, what u guys usin ?...I did a search but not much rolled up.
- New 750
Re: Oil...
14 Jun 2015 20:03
Right now I'm running shell Rotella 15-40,but prior to that I was using Mobil 15-50 full synthetic,the shell is fine but with the Mobil I noticed smoother shifts and less engine noise. I have heard mixed things about running synthetic in an engine this old with wet clutches, I noticed no ill effects! It's just crazy expensive when compared to the shell.
1977 kawasaki KZ750
- Tyler
Re: Oil...
14 Jun 2015 20:43 - 14 Jun 2015 20:45
This has got to be one of the most discussed tops on this site. Lots of options for sure. Rotella is a popular choice. I like Castrol 20-50 4t, the motorcycle specific blend.
2 rules to follow. Make sure it is JASO-MA or equivalent. This means it is designed to work with a wet clutch. And second, check it every time you ride.
If you do those things you won't have a problem.
"74 Yamaha DT 400 Enduro
Last edit: 14 Jun 2015 20:45 by Tyler.
