engine noise
- rlcarter
engine noise
10 Jun 2015 16:51
hello guys.. i just put a fresh rebuilt head on a 1980 kz1000G. the valve clearances were set at .007 the engine noise is noticeably louder. is this normal with that much clearance
1980 KZ1000 G w/carbs..
Re: engine noise
10 Jun 2015 16:58
Should be .002-.004. Why so loose?
- bountyhunter
Re: engine noise
10 Jun 2015 17:10
.007 is kind of wide. I run mine .003" - .005".
- rlcarter
Re: engine noise
10 Jun 2015 17:12
i bought it that way. could that be the reason for the noise
Re: engine noise
10 Jun 2015 17:24
If it has shim on top lifters, you could spit a shim. :ohmy:
- rlcarter
Re: engine noise
10 Jun 2015 17:36
yeah they are over the buckets . i will check them again thanks steve
