Horn
  • 650ed's Avatar Topic Author
Horn
05 Jun 2015 10:22 - 05 Jun 2015 10:28
#675382
Here is a comparison of the stock KZ650-C1 horn and a single FIAMM 72112 Freeway Blaster Horn (Low Tone - F) horn. I have the Fiamm horn tucked up inside the frame tubes behind the steering neck, and the stock horn still active - so both horns blow at the same time. I used a relay controlled from the stock horn wiring to directly connect the Fiamm to the battery when the relay is activated. Ed
Horn Video
[IMG
Here's how I wired mine:
Attachment HornWiringDiagram-2.jpg not found
Last edit: 05 Jun 2015 10:28 by 650ed.
The following user(s) said Thank You: harm
  • harm
  • harm's Avatar
  • Tom
Re: Horn
05 Jun 2015 18:39
#675444
Thanks Ed, that is what I should do i think. Thanks for the wiring diagram!
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Re: Horn
05 Jun 2015 19:01
#675447
