Please help identify mystery bushing KZ750H!
  • stoberto
  • stoberto's Avatar Topic Author
01 Jun 2015 13:12
#674794
Hello again everyone. I have an '82 KZ750H 4 cyclinder that I have slowly been rebuilding. The most recent project has been repairing the starter clutch. When taking out the oil pump, the phillips heads stripped - even using an impact screwdriver. So I drilled the heads off and then tapped out the bolts. My problem is that while tapping a mystery bushing fell out of the bottom of the engine. I can't see any logical place for it to go. The secondary shaft was still in, so it isn't from that. I have looked over many parts diagrams and I just can't figure it out. It looks similar to the clutch basket bushing, however that bushing is still there. I took a picture and posted below, if you know what it is please reply. Thanks so much!
  • KZB2 650
  • KZB2 650's Avatar
Re: Please help identify mystery bushing KZ750H!
01 Jun 2015 14:14 - 01 Jun 2015 14:20
#674803
Could it be one of the 2 knock bushings (pins) that holds the oil pump in........ Do you have a manual..... for my "650" it shows they are in the 2 holes closest to the 10mm bolt that holds the oil pump in too.
There should be 2 knock pins for the clutch cover too but I'm betting its from where you were tapping.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 01 Jun 2015 14:20 by KZB2 650.
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Re:Please help identify mystery bushing KZ750H!
01 Jun 2015 14:44
#674807
Hard to tell the size in the picture. Perhaps its the countershaft sprocket spacer?
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • stoberto
03 Jun 2015 12:42
#675136
Thanks for the help, I think I've settled on a spacer that goes on the outside of the secondary shaft on the opposite side of the bike. It makes the most sense, and I guess it's conceivable that it fell off the other side of the bike and bounced underneath. When it happened it just seemed like it fell straight out of the engine. I hope it's correct!
