Points housing?
- spdygon
Points housing?
01 Jun 2015 11:21Pic above is the points housing.
When I removed those two screws....little oil came out...do I need to put some gasket sealer when I reinstall them.
I have a Manuel but did not find anything on that.
Thx
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
- bountyhunter
Re: Points housing?
01 Jun 2015 13:07 - 01 Jun 2015 13:09
Don't think sealer is required. Probably won't hurt anything if you do.
Last edit: 01 Jun 2015 13:09 by bountyhunter.
- missionkz
Re: Points housing?
01 Jun 2015 15:01 - 01 Jun 2015 15:01
Hmmm... I am under the impression that there should be no liquid oil coming out from under that cover.... If yes, I would think you have a case crack or a crank end seal leak. Etc
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 01 Jun 2015 15:01 by missionkz.
- spdygon
Re: Points housing?
01 Jun 2015 15:10
There was no oil inside at all. Only when I removed those two screws very little on the tips.
I'll use some non Harding sealent.
Thx
Thx
1974 Z1 900 project
1974 Z1 900 project
- StreetfighterKz
Re: Re:Points housing?
01 Jun 2015 15:11
There is oil behind the inner cover. There should be no oil between the inner and outer points covers.
Looking at the parts diagram should show a gasket behind the inner cover and an oil seal in the middle of the cover. The only reason there is a gasket between the inner and outer covers is to keep out the elements.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- spdygon
Re: Points housing?
01 Jun 2015 15:14
U correct ....little oil came from inside the screw holes.
1974 Z1 900 project
1974 Z1 900 project
Re: Points housing?
01 Jun 2015 15:52
There's a drain hole at the bottom. You need a seal or there's something a miss with the housing. Now that I don't have points, it doesn't matter if moisture gets in.
- etbike3135
Re: Points housing?
01 Jun 2015 15:56
2 of the top holes from the points housing are drilled right trough into the case at the factory. You can use yamabond on those 2 screws.
1973 Kawasaki Z1
18 years in dragbikes
Re: Points housing?
01 Jun 2015 15:57
Wait a minute. Do you mean the outside screws where your fingers are? The gasket should seal them.
- 9er rider
- Keep a cool tool
Re: Points housing?
16 Jun 2015 06:14
I have the same problem, The P.O. just had to use a chisel to get the housing off and a leak at those two screws persist Its driving me nutz
Re: Points housing?
16 Jun 2015 07:30
Coat the treads with a little silicon.
The following user(s) said Thank You: 9er rider
- spdygon
Re: Points housing?
23 Jun 2015 17:53 - 23 Jun 2015 17:54
Well as I waited for complete engine gasket kit to arrive. ...over the last week still notice oil coming from the top holes.
Went back over my 77-78 Kawasaki Manuel and found that the top three do need non-permanent locking agent.
1974 Z1 900 project
1974 Z1 900 project
Last edit: 23 Jun 2015 17:54 by spdygon.
