Trying to source either OEM/NOS/Repro exhaust
- iowaboy
28 May 2015 15:58
I am having a difficult time trying to source a replacement exhaust for my 1978 Kawasaki KZ650 B2. I am wanting to retain the vintage look of my bike as much as possible, so this is why my preference is a stock OEM, NOS or reproduction of that configuration to replace the original exhaust that is starting to rust out, particularly on the bottom side. Any help, guidance, direction or advice would be greatly appreciated. Thank You in advance.
- MFolks
Re: Trying to source either OEM/NOS/Repro exhaust
28 May 2015 16:24
Try these websites:
Motorcycle Salvage Companies
www.cycle-salvage.com
www.motorcycle-recycle-center.com/
www.newrivercyclesalvage.com/index.html
www.bornagainbikes.net/
www.motolane.com/
www.motolane.com/
The following user(s) said Thank You: Randombeat
28 May 2015 17:47
GOOD LUCK finding a NOS set of 650 pipes. If you find them expect to pay $1000 USD or more.
28 May 2015 18:40
If the header pipes are in good condition & if the rust isn't too bad, you might be able to salvage the system.
They usually rust at the crossover connector pipe --- some guys have done a repair by using 1" copper pipe & fittings.
If the mufflers are shot, reproduction are available. Below is a photo of Verner-650's bike w/ aftermarket mufflers, but I don't know exactly which ones (probably Emgo dunstall replicas. ???).
HELIX RACING UNIVERSAL MEGAPHONE MUFFLER --- 20" L
HELIX RACING UNIVERSAL DUNSTALL TYPE EXHAUST MUFFLER ---26" L
EMGO UNIVERSAL DUNSTALL STYLE MEGAPHONE MUFFLER
(apparently, nla at jcwhitney. Not sure if JPCycles or anyone has them any more).
- Randombeat
- 0 to 100 real quick...
28 May 2015 18:50
Would the stock 4 to 2 sankei system off of a 1980 kz750h work?
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
28 May 2015 19:28
Look at the 650 Z mufflers near the bottom of the page in the link. They look very much like stock. Ed
www.escapesfantin.com.ar/kawa.html
28 May 2015 20:42Randombeat wrote: Would the stock 4 to 2 sankei system off of a 1980 kz750h work?
Those would be close. Might not bolt up just right in the back and maybe some brake pedal interference.
- Randombeat
28 May 2015 20:49
I've got the full system in good shape. Have toyed with the idea of selling it..
29 May 2015 06:26Randombeat wrote: I've got the full system in good shape. Have toyed with the idea of selling it..
Is it from a KZ650-B2? I ask because there are some big differences between the exhaust systems on some of the KZ650 models. Ed
- Randombeat
29 May 2015 11:28650ed wrote:Randombeat wrote: I've got the full system in good shape. Have toyed with the idea of selling it..
Nope, 1980 kz750h ltd. Hence the above questions on if it would fit.
