crankshaft replacement
- evol666love
25 May 2015 20:03 #673753
by evol666love
crankshaft replacement was created by evol666love
hello fellow kzriders.
well i was looking for some insight on replacing a kz750 b3 (78)crankshaft. not sure how much pain this is going to be the threads for the left handed threading on the crankshaft for the flywheel are pretty much done. i bought a new crankshaft and found a brand new bolt (that bolt new was hard to track down). I was hoping to be able to replace it without affecting my upper half of the engine. the motor is solid and ran solid. is it possible to break the lower half of the engine starting first with the oil pan than the lower half and replace any bearings and seals with the engine being upside down mounted to a jig. or is it going to have to be a complete rebuild sitting upright? i own a service manual. i just never tore into one of these verticle twins to this extent..
thank you for any direction you might be able to send my way.
- Thank you received: 2750
25 May 2015 20:06 #673755
by SWest
Replied by SWest on topic crankshaft replacement
I did it to my Ford truck but I never tried it on a bike.
The following user(s) said Thank You: evol666love
- evol666love
25 May 2015 22:26 #673768
by evol666love
Replied by evol666love on topic crankshaft replacement
well at least i can spread some sort of knowledge to the forum once i start this project i know i can do an overhaul. i'm just not doing well on the financial aspect. if it comes down to it if i have to tear it down to get to the crank shaft i might as well totally rebuild the engine. that i guess is the question.
- bountyhunter
- Thank you received: 337
26 May 2015 00:57 #673774
by bountyhunter
Replied by bountyhunter on topic crankshaft replacement
You need a factory manual. To change the crank is a complete teardown including a chain driven balancing mechanism the engine has in it.
- Thank you received: 2235
26 May 2015 05:25 #673783
by TexasKZ
Replied by TexasKZ on topic crankshaft replacement
Is it feasible to rethread the hole to th next larger size?
- Tyler
- Thank you received: 92
26 May 2015 07:09 #673815
by Tyler
"74 Yamaha DT 400 Enduro
Replied by Tyler on topic crankshaft replacement
What you really are trying to do is split the cases without taking the top end apart. I don't know if that is even possible.
Just thinking out loud for a minute...
You would need to pull the engine from the frame, pull the valve cover, remove the cam chain tensioner, then pull the cams - to get enough slack to get the chain around the crank, The flip it over and split the cases. Then remove the counter balancer chain, then pull the primary shaft and primary chain. Finally remove the rod caps and push the poisons down a bit. Then you could swap the crank
Maybe in theory it could be done, but you may just be the first person in history to try it on a 750 twin. Kawasaki would have you completely disassemble the entire engine to get to the crank. So trying to shortcut the whole thing and swap a crank may not be possible.
26 May 2015 07:15 #673816
by SWest
Some times the easy way is the hardest.
- evol666love
26 May 2015 15:24 - 26 May 2015 15:26 #673899
by evol666love
no i wish, its on the crankshaft. i won't fill and re-tap it either only cause the shaft is is holding the flywheel and i don't want that to be untrue and short out my charge system or damage it while I am riding it but thanks for the suggestion texaskz.
Last edit: 26 May 2015 15:26 by evol666love.
- evol666love
26 May 2015 15:35 #673903
by evol666love
so it might actually be a good point on ordering a complete engine gasket set or make my own. and order any new parts as needed after i see what is worn or out of tolerance. i have the service manual already. now would be a good time to up the engine to a bigger piston set and hone it. There is a motorcycle shop near by that said they could handle any machining that i may like to have done to it. any suggestions it's currently stock.
if you can point me to any references I would greatly appreciate it.
26 May 2015 16:08 #673911
by SWest
A new set of high performance pistons, $500 and go from there.
- zukdave
- Thank you received: 229
26 May 2015 16:18 #673914
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic crankshaft replacement
Theres no reason why you or a good machine shop could not put a Helicoil in the stripped hole.
As for the rotor it locate's off the taper not the bolt so thats a none issue.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- KZB2 650
- Thank you received: 265
26 May 2015 17:11 #673919
by KZB2 650
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Replied by KZB2 650 on topic crankshaft replacement
I'd Heli coil it like Zuk says the 500 dollar pistons are just the start......
1978 KZ650 b-2
