1988 kzp clutch
  • Alant99
  • Alant99's Avatar Topic Author
1988 kzp clutch
23 May 2015 20:54
#673410
I have a 88 kzp1000 that clutch was slipping . I changed the friction plates and the metal plates looked OK so I reused them. I assembled it and it still slips. Are the metal plates the problem or could I have done something wrong? I replaced the springs too. Any thoughts would be appreciated.
Re: 1988 kzp clutch
23 May 2015 20:59
#673412
Did you use the instructions in the Kawasaki Service Manual to adjust the clutch?
What motor oil are you using?
The following user(s) said Thank You: Alant99
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1988 kzp clutch
23 May 2015 20:59
#673413
Did you check the clutch adjuster inside the sprocket cover. It may be sticking. If it's the worm gear type, it needs to be greased and adjusted yearly or when you replace the cable.
  • Alant99
Re: 1988 kzp clutch
23 May 2015 21:06
#673417
Yes. I have a clymer manual and am using penzoil 10-40
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1988 kzp clutch
23 May 2015 21:11
#673419
You need a factory manual. The others use a "shot gun" approach and there are errors.
  • Alant99
Re: 1988 kzp clutch
23 May 2015 21:12
#673420
I will check that.
Re: 1988 kzp clutch
23 May 2015 21:13
#673421
Is the Penzoil motorcycle oil? In other words, does it have the JASO-MA designation on the container? If not, it more than likely is automotive oil with friction modifiers that will damage wet clutches. Definitely make sure whatever oil you use has JASO-MA marked on the container. Ed
  • martin_csr
  • martin_csr's Avatar
Re: 1988 kzp clutch
24 May 2015 05:46
#673448
Alant99 wrote: Yes. I have a clymer manual and am using penzoil 10-40
In what direction are you turning the clutch release adjusting screw? Manuals are sometimes ambiguous in that regard.
On many 80s models you're supposed to turn it counterclockwise first until hard to turn, then clockwise 1/4 turn.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1988 kzp clutch
24 May 2015 05:54
#673451
You may have the EZ pull style. The one with the ball bearings and ramp. In any event you should open it up, lube it set it at the relaxed position, put it together and start again. Might be simple as that or a sticky cable.
  • Alant99
Re: 1988 kzp clutch
25 May 2015 18:45
#673725
I changed the adjustment and that solved the problem. Thanks guys!
  • Alant99
Re: 1988 kzp clutch
25 May 2015 18:59
#673732
Yeah. I turned it counter clockwise and it stopped slipping
  • SWest
  • SWest's Avatar
  • 10 22 2014
