Best oil for 82 GPZ 750 synthetic or standard oil
  • Jrider
  • Jrider's Avatar Topic Author
22 May 2015 16:52
#673211
What is the best type of oil to use ob these vintage bikes. I have heard many stories. Is it safe to use synthetic r should I stick with regular ? also the best weight.,, thanks
1982 Kawasaki KZ 750 R , Stock
2007 Harley Davidson Police Electraglide
Re: Best oil for 82 GPZ 750 synthetic or standard oil
22 May 2015 18:30
#673224
Full synthetic works fine, but it MUST be motorcycle oil - not car oil. I have been using Mobil-1 Racing 4T for a number of years and it works great. Do Not use regular Mobil-1 car oil in the bike.
Here's the important information - whether you decide you use synthetic oil or standard oil it is very important that the oil you use in the bike has "JASO-MA" printed on the label. This will ensure that the oil chemistry will not damage the wet clutch in your KZ. There are numerous oils that meet this standard including some diesel oils. Most regular car oils have friction modifiers in them to improve gas mileage, and these will damage the clutch and make it slip.
Unless you live in an extremely hot climate or race the bike at the track you can use 10w-40 oil with no problem. I would not use 20W-40 or 20W-50 oil if there was a chance I would be starting the engine when the air temperature might be below 40-50* since higher viscosity oil doesn't flow as freely as lower viscosity oil when cold. The risk is that there could be insufficient lubrication when the engine is cold.
  • missionkz
  • missionkz's Avatar
22 May 2015 22:54 - 22 May 2015 22:54
#673249
I got a gallon of 15-40 Rotella T oil from K-Mart a couple-three weeks ago for $16.00 and I saw it was on sale even $2.00 cheaper at the local Auto Zone stores here in Denver.
It says JASO-MA on the back.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 22 May 2015 22:54 by missionkz.
  • bountyhunter
  • bountyhunter's Avatar
23 May 2015 01:04 - 23 May 2015 01:04
#673265
Syn or dino oil works fine as long as it is rated for motorcycle service. In the USA, about 98% of the oil sold as "full synthetic" is dino oil which has been subjected to a refining process called hydrocracking which removes some more impurities. "Full syn" may also be a blend of dino base and man made.
Last edit: 23 May 2015 01:04 by bountyhunter.
The following user(s) said Thank You: Randombeat, Jrider
