Soda blast questions
  • apbling
  • apbling's Avatar Topic Author
21 May 2015 13:25
#673016
Hi All,
About to soda blast and paint my 81 550 motor. It's not in too bad shape right now, but around the headers its kind of grimey. Was thinking of simple green, brush, wash, let dry, then soda blast.
Now, I haven't decided if I'll use the homemade setup or get the HF blaster, but either way my question is what air pressure do you guys use? Also, I assume it'll remove all the grime, but it will not remove the powdercoat on the fins/head, right?
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: Soda blast questions
21 May 2015 14:22
#673022
Soda blasting only removes staining to aluminum. You have to THOROUGHLY clean all the grease and grime first.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • apbling
Re: Re:Soda blast questions
21 May 2015 15:20
#673034
Oh. Great. Lol. I was under the impression it'd take grime off. Damn.
  • apbling
21 May 2015 15:37
#673040
Bad idea to use a pressure washer?
  • kaw-a-holic
  • kaw-a-holic's Avatar
21 May 2015 17:24
#673052
You would have to keep all the water out. If the cases are coming apart no big deal.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • harm
  • harm's Avatar
  • Tom
21 May 2015 17:40
#673057
apbling wrote: Bad idea to use a pressure washer?
Thats what i did but as kaw-a-holic said you have to make sure no water gets in. i made some plugs with o-rings to seal the intake and exhaust ports
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
  • apbling
21 May 2015 18:57
#673067
Hmmm. Well I think I'll just do it the old fashioned way...by hand. I made the homemade soda blaste tonight. Worked ok...had feed issues. Might try that HF pinkish colored gun.
  • Nessism
  • Nessism's Avatar
  • Online
  • davido
  • davido's Avatar
22 May 2015 08:41
#673143
I cut some small 10mm MDF plates which I bolted onto the inlet ports (with a line of silicone sealer around each one) and on the exhaust ports and starter hole,I stuffed plastic bags into them,then filled the port with silicone. Worked a treat No water getting in there!!
The next time I do it though,I would grease the exhaust ports so the silicone will come out again with no drama.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
