Slipping starter
  • WaldekPL
  • WaldekPL's Avatar Topic Author
Slipping starter
20 May 2015 03:41 - 20 May 2015 07:23
#672822
Hi everyone !
I've got problem with my starter. When engine is cold i can't blast off engine. But if engine catch temperature starter does not slip. I try to grind abotu 0,08 mm from starter clutch gear but it does not work. I think to buy used startet cluch and starter cluch gear but in Poland i cant find this parts to kawasaki kz 1100 or gpz 1100. Do you know any other models that have the same parts as the model kz 1100. In my country there is a lot of kawasaki 750 but i do not know it is will fit. Or maybe you have others ideas ?? Regards Paul
Year 1981, model Z 1100.
Kawasaki Z1100
Last edit: 20 May 2015 07:23 by WaldekPL.
  • PaintWorkz
  • PaintWorkz's Avatar
Re: Slipping starter
20 May 2015 06:09
#672843
What year and model is your bike? Look on eBay for a good use one...... make sure you get the right year and model. I bought a used 1985 Gpz900 starter clutch on eBay for my 1984 Gpz900 and the gears were different. My 84 had a cracked housing so I just used my cleaned up gear with the good 85 eBay housing. This fix required splitting the cases on my Ninja 900. :ohmy:
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
  • TexasKZ
  • TexasKZ's Avatar
  • Away
20 May 2015 17:26
#672915
Looks like that starter clutch was used on many years and models. Happy shopping!
www.partzilla.com/parts/detail/kawasaki/KP-13193-1006.html
