Head gasket
  • bromz
  • bromz's Avatar Topic Author
  • 1981 kz1000 csr
Head gasket
14 May 2015 07:38
#672047
Can I reuse a head gasket with only 100 miles on it? Had to have a valve stem seal pop off.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Head gasket
14 May 2015 08:54
#672064
You can and I have in a pinch. I used silver spray paint on it in the past. Now there is copper coat. It would be better to use new gaskets but if you have to, tighten it down and re tighten it after a few warm ups. It is already compressed so I'd check it and tighten it more times than usual. :whistle:
  • bountyhunter
  • bountyhunter's Avatar
Re: Head gasket
14 May 2015 12:19
#672098
I did it too. I used the copper spray head gasket sealer although I don't know if that is mandatory.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Head gasket
14 May 2015 12:40 - 14 May 2015 12:41
#672101
bromz wrote: Can I reuse a head gasket with only 100 miles on it? Had to have a valve stem seal pop off.
:unsure: If you get a leak, you will immediately know why...
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 14 May 2015 12:41 by daveo.
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Head gasket
14 May 2015 19:45
#672165
swest wrote: :woohoo:
:whistle:
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Head gasket
14 May 2015 21:38
#672185
:whistle:
B)
