1980 kz750e1 crank and rod bearings
  • pbkracing
  • pbkracing's Avatar Topic Author
12 May 2015 19:59
#671860
hey guys I need crank and rod bearings to complete my 810 motor rebuild. Anyone know where I can find some..
  • Nessism
  • Nessism's Avatar
  • Away
Re: 1980 kz750e1 crank and rod bearings
13 May 2015 14:27 - 13 May 2015 14:37
#671964
Just checked on-line and it seems the bearings are still stocked by Kawasaki. You need to figure out what color code bearings you need then either hit up your local dealer or order from one of the multitude of On-line OEM Kawasaki part sources. I'm not sure what the best source is but Partzilla is worth a look.
Last edit: 13 May 2015 14:37 by Nessism.
