Cylinder block rubber O rings
  • missionkz
  • missionkz's Avatar Topic Author
12 May 2015 12:45
#671793
What, if any, are you builders using for the O-rings under the cylinders?
I'm looking at mine fresh cylinder block... no O-rings at all and I can't remember pulling them off.
The Kaw part # is 92055-054.
Kinda pricey at anywhere from $28 to $40 for a set of 4.
However, there is a place here in Denver that sells the Bruna-N 70s O-rings for about $0.75-$1.00 each, but the max temp rating is under 240F/115C.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Cylinder block rubber O rings
12 May 2015 12:52
#671795
If you rebuild the motor and purchase a full gasket set for your KZ1000, then the cylinder o-rings should be included...certainly they were in the sets that I have purchased. :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • bountyhunter
  • bountyhunter's Avatar
12 May 2015 13:00
#671796
I would use Viton. There are a lot of them around. I found the ones for my hydraulic jack on ebay. Viton is way better than butyl rubber.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
12 May 2015 13:04 - 12 May 2015 13:05
#671797
bountyhunter wrote: I would use Viton. There are a lot of them around. I found the ones for my hydraulic jack on ebay. Viton is way better than butyl rubber.
Agreed....if you need a measurement, I can look at the uninstalled ones I have.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 12 May 2015 13:05 by Mcdroid.
