valve spring height
- THR
valve spring height
11 May 2015 17:52
Where can I find a valve spring height micrometer for a kz 1000?
79 KZ 1000 MKII
- Tyrell Corp
Re: valve spring height
11 May 2015 17:59
Doh! vernier calipers or a micrometer. Manaul lists minimum spring lengths, over the years these may reduce below service limit....particularly if a motor has been stood for years with one valve compressed.
11 May 2015 18:11
No eBay APP ID and/or Cert ID defined in Kunena configurationAny dial calipers should work. See example in link. Ed
11 May 2015 18:33
If in doubt, replace them.
- zed1015
12 May 2015 00:34
Standing the springs against a steel rule will do the trick.
