79 kz650 loss of power
Re: Re:79 kz650 loss of power
12 May 2015 11:22
#671780
The spring that wraps around the air duct at the carb is enough to seal it. Ed
  • bikerdave79
  • bikerdave79's Avatar Topic Author
12 May 2015 11:45
#671785
My airbox boots are just barely on. Like they shrunk a bit or something. The spring seems like it's not really doing much
  • davido
  • davido's Avatar
12 May 2015 11:51
#671786
When you checked the carbs did you check your jet sizes? It seems unlikley that they were changed if everything else is standard but often the problem can be found in things you take for granted. (did I just sound like Yoda there?Or Grasshopper??)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • bikerdave79
12 May 2015 12:21
#671790
No I did not. I assumed they are original. I'm going to tear them down tonight and check everything again. What should the jet sizes be? Assuming they are original?
  • bikerdave79
12 May 2015 14:04
#671808
97.5 is what the main jets say
  • bikerdave79
12 May 2015 14:24
#671814
All jets clean accel pump working. I'm at a loss here
12 May 2015 15:28
#671820
bikerdave79 wrote: No I did not. I assumed they are original. I'm going to tear them down tonight and check everything again. What should the jet sizes be? Assuming they are original?
First determine if you have air screws or pilot screw (or unlikely - both). Then take a look at the charts below. ed
Attachment CarbSpecsJetting.jpg not found
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 May 2015 16:03
#671822
Try adjusting the accelerator pump. Look closely at the diaphragm to be sure it's not cracked or has a hole in it. Check balls too. The carbs are set up lean and the pump makes up the difference. If there is a leak, when you back off, fuel is sucked into the intake causing a over rich condition and back fire. I'd check both diaphragms on the bottom of the carbs.
  • bikerdave79
12 May 2015 17:17
#671827
It fixed!!! After removing the carbs entirely, going over them, checking jets, float levels, pump diaphragms the carbs looked to be in excellent shape. Upon putting them back in I decided to smoke the airbox with an evap smoke machine for cars. Well I found out the lid that holds the filter In was cracked. And that cyl 2-3 intake boots were heavily leaking. after taping up the culprit so that everything is air tight... She hits on all four and runs like the wind. So I guess that little bit of air creeping past was enough vacuum loss to cause a problem. Yikes. Just an fyi if anyone else is having trouble with this type of thing.
  • bikerdave79
12 May 2015 17:18 - 12 May 2015 17:27
#671828
And PS those spring type clamps are junk. I replaced with actual band clamps. Big difference
Last edit: 12 May 2015 17:27 by bikerdave79.
12 May 2015 17:36 - 12 May 2015 17:38
#671830
Interesting. My airbox ducts fit so tight on the carbs the springs aren't really necessary even though I always use them. Did you find the ducts to be a tight fit on the carbs? I wonder if they had been replaced at some point with something a little larger size? Ed
Attachment 00003a-31.jpg not found
Last edit: 12 May 2015 17:38 by 650ed.
  • bikerdave79
12 May 2015 20:30 - 12 May 2015 20:30
#671871
Your bike looks to be in WAYYY better shape. Lot more oxidation on my engine parts, rust, airbox boots are all stiff and hard and take much effort to even get them halfway on. NY bike that spent most off seasons outdoors so I'm sure that didn't help.
Last edit: 12 May 2015 20:30 by bikerdave79.
