End Cam Cover Seals
- skooterbum4real
End Cam Cover Seals
09 May 2015 08:37
I'm questioning the four, half circle rubber seals, that go in the end / side of the valve cover, along with the cover gasket.
This is the second set of these seals that I've purchased. The first set was made from a solid piece of rubber, molded into a half circle.
The set that I just received has a metal piece in the end / side of it, that fits on the outside / outer edge of the valve cover, then the center of it is hollow. I hope this explanation is understandable......LOL
I'm questioning how well these will actually seal with the hollow center ??
Any comments ??
Ron
Any comments ??
Ron
1978 KZ650B 8,500 miles
1976 KZ750 Twin
SPECIAL CONSTRUCTION V-TWIN CHOP
1976 KZ750 Twin
- Randombeat
- 0 to 100 real quick...
Re: End Cam Cover Seals
09 May 2015 11:16
Which bike is this for? Pics or link to the seals in question?
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
- chconger
09 May 2015 20:01skooterbum4real wrote: The set that I just received has a metal piece in the end / side of it, that fits on the outside / outer edge of the valve cover, then the center of it is hollow. I hope this explanation is understandable......LOL
I just replaced mine with the type your describing. They seal fine.
...And I agree, seems like an odd design.
1977 KZ 1000-A
