85 zn700
  • missionkz
  • missionkz's Avatar
Re: 85 zn700
04 May 2015 10:55 - 04 May 2015 10:57
#670645
Switch the spark plug wires around (1 and 3 with 2 and 4) and see if the firing and or non firing follows the plug wires. If yes, then the spark plugs, plug wires or spark plug boots are probably bad.
If it is a two coil system... there is not two coils in each package.... there is only two ends to the same coil and a spark plug connected to those ends.
If the coil on 2 and 3 was bad, 2 and 3 would not fire.
If the coil on 1 and 4 was bad, 1 and 4 would not fire.... etc.
That is not what you are seeing so I would first suspect what is in between the coil and the spark plugs, including the spark plugs.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 04 May 2015 10:57 by missionkz.
The following user(s) said Thank You: bb41077
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 85 zn700
04 May 2015 11:37
#670649
If the wires are the replaceable type, Inspect the ends both at the coils and the plug caps. Could be corroded and you can cut 1/4" off, screw them back in and run it.
  • bb41077
  • bb41077's Avatar Topic Author
Re: 85 zn700
04 May 2015 13:09
#670665
Can I switch um at the coil post or redirect the wires to the plugs when I do that. Will it f it up if I change them at the post to see if they fire
Bruce Bakken
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 85 zn700
04 May 2015 21:36
#670723
Disconnect them and look at them. If you see any green SHT or black burnt, trim the ends and put them back on.
  • bb41077
Re: 85 zn700
06 May 2015 15:09
#670910
Well trimmed them up and good to go. Now if I can get it to stop pissen gas out of the carbs, life would good cuz the wind would be blowing my beard....
Bruce Bakken
