Vance & Hines header
  • Dale5256
  • Dale5256's Avatar Topic Author
03 May 2015 07:38
#670486
I have a 1982 LTD 1000 with stock air box which runs perfect. Vance & Hines does not make header for this model. I would like to install a vance & hines header on this bike with a baffle. I will be keeping the stock air box. I will rejet. This is a steet bike. This bike is very quiet with stock exhaust. Would like to make a little more noise for safety sake also is 1 jet size big enough? Thanks for the help
1982 LTD. 1000
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Vance & Hines header
03 May 2015 07:57
#670488
I don't see why one off a KZ1000 won't fit unless the mount is in a different place. The one I have was supposed to fit the Z1/KZ 900/1000's. It came with a stock baffle and I got the competition and drag baffles. The stock baffle was restrictive so one size jetting would have worked.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
03 May 2015 09:03 - 03 May 2015 09:17
#670493
V&H tech said "forget it", but considering the J-model 1000 and 1100 engine and frame-cradle are essentially the same, I opted for the V&H 13009-J regardless. :)
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 03 May 2015 09:17 by daveo.
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 May 2015 10:39
#670496
Why did they say forget it? Your stinger is lower than mine, is that it?
  • Dale5256
03 May 2015 11:20
#670501
Do u think the 13009-J will fit the 1982 LTD 1000
1982 LTD. 1000
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
03 May 2015 11:59
#670504
swest wrote: Why did they say forget it? Your stinger is lower than mine, is that it?
The Pro Pipe/drag model is the only header V&H has available for the KZ1100A. I prefer leaning into right turns which could be problematic with that one. Other than the Mac, the options for my bike are basically none.
Regarding my stinger...I don't know. :unsure: I'll ask my wife.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
03 May 2015 12:15 - 04 May 2015 19:19
#670506
Dale5256 wrote: Do u think the 13009-J will fit the 1982 LTD 1000
I believe that model was designed specifically for the 1982 KZ1000-J
You may have to take the chance and modify something to make it work on your bike. In my case, the rear foot-rest bracket is longer than the KZ1000-J, requiring a spacer on the collector flange, and the megaphone mounting tab needed to be tweaked to align properly. The megaphone slips over the header by only 5/8", but it works very well...oil/filter changes are a breeze, and the center-stand comes in handy more often than not. The baffle options V&H has available for this header make a typical Harley sound like crap.
Last edit: 04 May 2015 19:19 by daveo. Reason: upgrade
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 May 2015 13:37
#670512
Dale5256 wrote: I have a 1982 LTD 1000 with stock air box which runs perfect. Vance & Hines does not make header for this model. I would like to install a vance & hines header on this bike with a baffle. I will be keeping the stock air box. I will rejet. This is a steet bike. This bike is very quiet with stock exhaust. Would like to make a little more noise for safety sake also is 1 jet size big enough? Thanks for the help
Put up a pic of the right side of your bike so that we can help you chose.
  • Dale5256
03 May 2015 19:10
#670562
Thanks Steve I am having trouble sending you pictures do u have a email i
1982 LTD. 1000
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 May 2015 19:43
#670566
Just sent you a PM with my e-mail.
  • Dale5256
04 May 2015 03:20 - 04 May 2015 03:36
#670604
2 pics
1982 LTD. 1000
Last edit: 04 May 2015 03:36 by Dale5256. Reason: Up side down
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
04 May 2015 19:31
#670713
Dale5256 wrote: 2 pics
The 13009-J might possibly bolt right up, but have your bike right side up before trying it. :laugh:
You might research the rear peg mounting bracket, if it is the same part number as the 1000-J. If so, you may have a no-brainer project.
