GPZ throttle body wanted
  • bneedy
  • bneedy's Avatar Topic Author
15 Apr 2015 12:12
#668074
Looking for a complete throttle body from a GPZ for adapting to a KZ1000. Thx.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: GPZ throttle body wanted
15 Apr 2015 12:29
#668079
Are you seeking those from a 1981 GPz1100 or a 1982 GPz1100? The first has no injectors on the TBs, the second does.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • DFIGPZ
  • DFIGPZ's Avatar
16 Apr 2015 13:53
#668240
What do you plan on driving the inj With ? if it were me I would use 83/84 1100 system.
1984 750 Turbo
  • gpz1170
  • gpz1170's Avatar
17 Apr 2015 11:33
#668404
pm sent
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
  • bneedy
01 Dec 2015 13:49 - 01 Dec 2015 13:49
#701421
Thanks for your responses. My apologies for my late reply, I have not been on much. I have since picked up a few of each type to play around with. I have projects with both injected and carbureted heads. First, an '82 will be used on an '80 EFI head as the ports were plugged during porting. It will be driven with a Microsquirt once the engine is broken in on carbs. (May use the same with the others as I am told that the '82 throttle body is better, due to the injectors being further away from the heat.)
Last edit: 01 Dec 2015 13:49 by bneedy. Reason: typo
