Need help finding exhaust for my bike
- sethmahan
13 Apr 2015 07:38 - 13 Apr 2015 07:40
I have a 1983 kz1100 LTD, shaft drive. I bought it and it did not have the original exhaust, it was replaced with a crappy 4-1 system that didn't match the bike, and the muffler is way to small to fit. However, I can't afford to buy the original exhaust right now, (although I found the whole system, with mufflers for $120 so it will not be long) so I need to masks these headers work for now. Can anyone recommend a muffler that will fit, or at least be close, for a temporary fit? The pipe on the headers is 3 inches, and I'm not sure what they were originally attached to. And I do know that using the wrong exhaust could make my bike run poorly but I have no other options right now. Thank you for your help
Last edit: 13 Apr 2015 07:40 by sethmahan. Reason: Spelling error
Re: Need help finding exhaust for my bike
13 Apr 2015 11:51
You can probably use the muffler can from any 4-1 system from a big Kawasaki.
Be sure to check the spark plugs, as the po may not have properly jetted the carburetors.
Is the stock airbox installed or individual filters?
- sethmahan
13 Apr 2015 12:05
Do you have any idea what 4-1 it is? If you post a photo, someone might be able to identify it so that you can proceed accordingly.
I'd guess the po didn't rejet the carbs, but that it just a guess. Maybe he did. ???
At any rate you'll need to check for yourself. If the spark plugs seem lean (whitish), you could get a new muffler, then rejet. Someone might be able to give jetting advice to get the carbs close.
- sethmahan
13 Apr 2015 12:17
No, I have no idea. The guy I bought it from basically cobbled it together from spare parts, but he only wanted $100 for it so I took it. I don't have pictures to post right now
