Will this exhaust fit on my bike?
- TheForumTroll
08 Apr 2015 00:29
Hello again experts :side:
I'm sitting here without my service manual or bike and trying to figure out what kind of mufflers will be a relative easy fit to a kz700 (as close to bolt-on as possible) but I have no idea what to look for. Anyone know if something like this will fit:
www.wats-motor.com/product_info.php/cPat...8_82/products_id/431 :huh:
-[ KZ700-A1 '84 ]-
Re: Will this exhaust fit on my bike?
08 Apr 2015 00:58 - 08 Apr 2015 00:58
The stock KZ700 mufflers have recesses in them --- not sure if the recesses are for center stand clearance or axle clearance or what. ???
Last edit: 08 Apr 2015 00:58 by martin_csr.
- TheForumTroll
08 Apr 2015 01:22
On the back/inside? That's a good question. I would guess it is for the centre stand ..
-[ KZ700-A1 '84 ]-
08 Apr 2015 01:37 - 08 Apr 2015 01:39
After checking some pics, the recesses seem to be pretty far back, so I think they're for the swing arm or axle & axle nut clearance. The KZ700 mufflers angle in, so clearance may not be an issue w/ aftermarket.
Last edit: 08 Apr 2015 01:39 by martin_csr.
The following user(s) said Thank You: TheForumTroll
08 Apr 2015 05:03
If your original exhaust system is in good shape don't cut it. It is worth $$$. If that is the case you would be better off selling it and buying a whole new exhaust system. Not only will you be assured that everything will work properly; you may even come out ahead on the deal depending on the condition of the original system. Ed
08 Apr 2015 07:03
He's kinda fortunate as the KZ700 stock mufflers are clamped in place, so trying something different is easy.
08 Apr 2015 08:15
Thanks; I didn't know that. That sure does make it easier! Too bad the KZ650 exhaust isn't made that way as it sure would make it simple to replace a damaged muffler. Ed
- TheForumTroll
08 Apr 2015 11:48
A muffler like that instead of the original would likely make the bike run more lean, right? It is already lean so if it does I might have to fix that.
-[ KZ700-A1 '84 ]-
08 Apr 2015 15:59
The 4-1 systems typically flow more air, but I have no idea how the universal fit mufflers perform. I guess install new spark plugs at the same time & go for a test ride, then check the plugs. Or since the carbs are already lean, maybe go ahead & increase the jets a size or two, then do the test ride thing. ???
