Exhaust equalizer pipe: running temperature?
- HBKwaka
Re: Exhaust equalizer pipe: running temperature?
08 Apr 2015 17:43
I replaced the original exhaust on my KZP with a new 2into1 and they did not have the crossover pipe the original exhaust had. Runs better and more power.
- HBKwaka
Re: Re:Exhaust equalizer pipe: running temperature?
08 Apr 2015 17:47KzChop82 wrote: Ed- do you have a laser temp gauge?
Does anyone on here have one?
I do
08 Apr 2015 18:32
I don't. Why? Ed
08 Apr 2015 20:50 - 08 Apr 2015 20:51Do you mean a 4-1 or 4-2? Also, did you compare the ID of the pipes? I bet they're larger in diameter. One 2" ID pipe will flow much more air than two 1" ID pipes. I don't know about other models, but the 81 KZ650 pipes are quite narrow just after the connector & if you eliminate the cross-over, the exhaust port size is reduced by half & it will be quite restrictive.HBKwaka wrote: I replaced the original exhaust on my KZP with a new 2into1 and they did not have the crossover pipe the original exhaust had. Runs better and more power.
Last edit: 08 Apr 2015 20:51 by martin_csr.
- HBKwaka
08 Apr 2015 23:00 - 08 Apr 2015 23:01
2to1 per side. I was trying to splain the non crossover type but yes its 4into2. I didn't compare the diameter. I jus replaced the shoddy police exhaust that was thrashed. I dunno but i do think that without the crossover it seems better but I have to add that it was bored out to 1075 and rejetted along with Wisco pistons...ydayada
Last edit: 08 Apr 2015 23:01 by HBKwaka.
- KzChop82
09 Apr 2015 03:53650ed wrote: I don't. Why? Ed
Because I'm trying to find someone who has one- and can take a short ride and then get a temperature reading from the exhaust crossover pipe.
Clinton, NJ
Custom chopper, 1982 KZ 1000 M2 CSR engine, K&N Pod Filters
PICTURES AND GOPRO VIDEOS!! :
www.dropbox.com/sh/jipz3l8nhzr4jge/AABbm...OC3sqlhCSLxH5Fa?dl=0
09 Apr 2015 05:44
That's a good idea. Sorry I don't have one or I would do it for you. Ed
- KZB2 650
09 Apr 2015 06:25 - 09 Apr 2015 06:32
Search "engine temps" ............. Old man rock was getting around 370 degree's at the header pipes so the under neath "should be lower I would think".
On page 2 look for operating temps I think its called ....... you were on it I think a while back.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 09 Apr 2015 06:32 by KZB2 650.
- KzChop82
09 Apr 2015 06:46Ed- no problem.650ed wrote: That's a good idea. Sorry I don't have one or I would do it for you. Ed
The piping is good to 500*, so it should be fine.
In fact- got it up to running temp today and it looked fine.
The bike finally lives again!!
Just needs a carb tune.
Clinton, NJ
- TheForumTroll
09 Apr 2015 07:15
I don't have anything to measure the temperature on my bike, but I remember from racing that the temperatures didn't get that high. Google found these numbers from cars:
So unless you make it into a high performance racer, I'd say you should be in the green :woohoo:
- 1" from engine 750º F.
- 2" above header port (on header) 300º F.
- 1" above floor pan (in car) 165º F.
-[ KZ700-A1 '84 ]-
09 Apr 2015 07:23Thanks. Aftermarket pipes are typically larger in diameter. I took the earlier comment as meaning the connector pipe isn't necessary on the stock systems.HBKwaka wrote: 2to1 per side. I was trying to splain the non crossover type but yes its 4into2. I didn't compare the diameter. I jus replaced the shoddy police exhaust that was thrashed. I dunno but i do think that without the crossover it seems better but I have to add that it was bored out to 1075 and rejetted along with Wisco pistons...ydayada
- KzChop82
09 Apr 2015 08:37TheForumTroll wrote: I don't have anything to measure the temperature on my bike, but I remember from racing that the temperatures didn't get that high. Google found these numbers from cars:
Awesome- thanks!
Clinton, NJ
