clip on valve seals
  • jlat
  • jlat's Avatar Topic Author
clip on valve seals
05 Apr 2015 18:07
#666686
hello people; I'm new. Any tricks in getting them off or do you just replace them? Are all the valve seals on KZ's clip on?
IBBY
  • chconger
  • chconger's Avatar
Re: clip on valve seals
05 Apr 2015 20:09 - 05 Apr 2015 20:12
#666709
Hi Ibby
They should just pull out. They may be hardened from age. You need to replace them, so don't worry about destroying them. Just grab on the plastic and pull /tear away. Just make sure your not grabbing on the metal guide they are attached to.
Cheers
Chris
1977 KZ 1000-A
Last edit: 05 Apr 2015 20:12 by chconger.
  • DFIGPZ
  • DFIGPZ's Avatar
06 Apr 2015 04:15
#666733
they just push on buy more than likely hardened from age best to replace with viton seals let me know if i can be of any help locating the proper seals.
1984 750 Turbo
