1977 kz 1000C cam specs?
  • elkbuster
  • elkbuster's Avatar Topic Author
05 Apr 2015 11:43
#666633
Hi guys & gals,
I am in need of cam specs for the above cam. I just swapped out the cams from a 1977 to a 1980 kz 1000c engine. Is this swap doable? I need the specs as I put APE adj. cam sprockets on. I did stay with the 32 sprockets as opposed to the 30t sprockets that were in the 1977 motor. Any advice is appreciated.
1980 KZ 1000 C3
N CENTRAL WA
  • zed1015
  • zed1015's Avatar
Re: 1977 kz 1000C cam specs?
05 Apr 2015 15:01
#666653
All cams from z1 to mk2 are the same spec with a little variation due to manufacturing tolerances so this is a straight swap.
Set timing at 110 degrees for std spec.
The following user(s) said Thank You: elkbuster
  • elkbuster
05 Apr 2015 18:54 - 05 Apr 2015 18:56
#666701
zed1015 wrote: All cams from z1 to mk2 are the same spec with a little variation due to manufacturing tolerances so this is a straight swap.
i have not timed cams before and I am running into problems. So I find TDC on the exhaust cam. I set the camwheel to 0 deg after finding true TDC I then set the dial guage on the #1 exh cam bucket and turn engine in normal clockwise position until I find where the valve is open at the peak rise of the cam. Once I find peak rise in cam, I set the dial indicator to "0". I record degrees from the cam degree wheel at this point. This is where I get confused on the next step. Can you walk me through the rest of the procedure?
1980 KZ 1000 C3
N CENTRAL WA
Last edit: 05 Apr 2015 18:56 by elkbuster. Reason: more information
  • zed1015
  • zed1015's Avatar
06 Apr 2015 05:00
#666738
Here's a link to one of many sites that explain the procedure. ( much quicker than me typing it all out).
www.muzzys.com/articles/lobe_centers.html
Read through it step by step several times and it will become clear.
It's not hard to do once you get the hang of it.
The trickiest part is rigging up the dial gauge pointer to stay on and follow the valve bucket smoothly and you may need to make up a special fixture to mount the gauge on to the head.
  • elkbuster
08 Apr 2015 00:50
#667053
zed1015 wrote: Here's a link to one of many sites that explain the procedure. ( much quicker than me typing it all out).
Got 'er done! Thanks. That is the best article I have seen so far.
1980 KZ 1000 C3
N CENTRAL WA
