1 and 4 not sparking
  • conman846
  • conman846's Avatar Topic Author
01 Apr 2015 14:16
#666096
As the title says, 1 and 4 are not sparking. After reading a lot on this forum and my manual, here's what I've done:
Bike is a 1982 kz550
1. Made sure both coils work by switching them. Still only 2 and 3 fired.
2. Tested both pick ups for ohms. They both read inbetween 400-500 ohms.
3. To test the IC Ignitor I ran a screwdriver over the pickups to force a spark. When I did this the pickup for 2 and 3 sparked, while the pickup for 1 and 4 did not.
So I think my Ignitor is bad, or the ground wire from the ignitor to the coil that fires 1 and 4 is bad.
Does anyone have any suggestions to test this problem further?
Thanks for any help
  • mopguy
  • mopguy's Avatar
Re: 1 and 4 not sparking
01 Apr 2015 17:00
#666128
Lpoks like the coil is not getting any power, or the leads to the sparkplug are defective. Hope this helps.
  • mike1957
  • mike1957's Avatar
01 Apr 2015 18:09
#666137
Before you go and get a new ignitor which can be expensive If both your coils were tested good seems
you could possibly have a problem with your wiring or spark plugs.Check your primary wiring with a ohm
meter make sure you don't have a open some place. then check your secondary
wires . also check your spark plugs Check your pick up coils.Make sure you
the gap is correct on the p/u coils.also check for a open wire leading
to the p/u coils.Do the easiest and less expensive things first.
mike1957
  • mike1957
  • mike1957's Avatar
01 Apr 2015 19:15
#666141
Just thought to mention to check your connector to the p/u coils make sure
it didn't come disconnected and that there's no corrosion there. You should
also have a fully charged battery.If you check your manual it explains
how to check your igniter hope this helps
mike1957
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Pedrosky750ltd
  • Pedrosky750ltd's Avatar
22 Apr 2017 08:07
#759882
Hi, did you figure out if it was the igniter causing the problem? I'm having the same issues. Thanks.
