Hanging revs..
- 78z1Joe
- My man cave is my garage....
Re: Re:Hanging revs..
04 Apr 2015 16:47
Hi I had a similar problem a few years back. After searching and testing and cleaning the carbs a few times, I happened to check the screws which connect the individual carb linkage to the long rod which is attached to the bell crank to which the cables are attached. Sorry if my terms are incorrect, but basically check the screws that hold the linkage to the carbs. I found one of mine was loose which allowed that carb to lag behind the rest when slowing down.( shutting the throttle). The yellow factory "Locktite" dried out after more than 30 years, go figure! Good luck and cool bike.
Joe
Joe
1978 KZ 1000
1982 GS 300 training bike
Previous Rides...
75 RD 350
72 CB 500 Four
72 SL 125
71 CT 70
69 3 1/2 HP mini bike
Previous Rides...
75 RD 350
72 CB 500 Four
72 SL 125
71 CT 70
- bromz
- 1981 kz1000 csr
11 Apr 2015 04:58
This is stretching it but one time when I had hanging revs I had put my tank back on and the tank was pinching the throttle cable. Oops. Just something easy to check
- LuckyLucOnBass
11 Apr 2015 17:07
I forgot to update this. I was warming up my bike. I heard a little bit of air escaping. One of my vacuum plugs had a tear in it. The factory plug on the 3rd carb holds up great. The new rubber plugs need replacing almost every year. Anyway, one new plug later and my bike was running great. Took her around the block and she ran fine.
bass player, bike rider, hockey fan.
1983 KZ550 M1
1983 KZ550 M1
11 Apr 2015 20:59
Z1E offers a set of stock-equivalent vacuum plugs:
Click here > www.z1enterprises.com/ItemDetails.aspx?i...plugs&item=KL11-4972
