timing f*** up
- jlat
timing f*** up
30 Mar 2015 15:00
hello people; I'm new 77 1000 project. I have my project in my basement and my excuse is. (A) It's not the best in lighting. (
My vision is getting to be a problem. I couldn't see that timing arrow and my cams have that arrow and some lines that are not shown in a factory manual. It is in the same manual but in a supplement. I set my timing to the lines and I might of bent the valves? I have the head of and all the intake valves have marks were they probably hit the pistons. Funny I don't see any marks the pistons.
More fun and games.
IBBY
More fun and games.
IBBY
- Kwaker2000
Re: timing f*** up
30 Mar 2015 15:55
thats bad news maybe think about getting a inspection lamp for next time ,hope you sort it out
- bountyhunter
Re: timing f*** up
30 Mar 2015 17:16
I use a lamp similar to this one.
Attachment aaaaa.jpg not found
- RonKZ650
Re: timing f*** up
30 Mar 2015 17:22
I think the valves hit each other when this timing mishap occurs, but could be valves hitting the pistons I suppose. Either way, yes you have bent valves. Pour gas into the combustion chamber and watch it leak out the intakes most likely. I bent all 4 intakes when I did this mistake.
Re: timing f*** up
30 Mar 2015 17:45 - 30 Mar 2015 17:47
If you buy one of these (Princeton Tec - Apex) you will wonder how you ever survived without it! Multiple brightness settings for both spot and flood and it has a regulator so the light output does not dim at all until the batteries are shot, and that takes a LONG time. I bought it for use when entering and leaving the woods in the dark when hunting, but I found it just as useful for working on the car, bike, or poorly lighted areas of the house like the attic or furnace room. Because it mounts on your head and is fully adjustable the light ALWAYS shines exactly where you need it. It is one of the most useful tools I have. Ed
www.princetontec.com/apex
Last edit: 30 Mar 2015 17:47 by 650ed.
- Zephyrrider
Re: timing f*** up
30 Mar 2015 18:23
Dam sorry to hear that jlat
My eyes are not so good close up any more - what a bastard that is
I use my 2 x specs now for that stuff and a 550 lumen headlamp which lasts about 5 hours before recharge
Have seen them up to 1500 lumen but the one i have got is very bright and you can take it anywhere like EDs - great for anything. Have tried the magnetic work lamps but they dont fit everywhere on a bike so found it a bit useless really - probably good on a car but i havnt got one of those things .
Mick
1994 ZR750 Zephyr C4.
- RonKZ650
Re: timing f*** up
30 Mar 2015 19:48
Many a guy has made this mistake. I did it close to 30yrs ago, can't blame it on my eyes or lack of light, just confusing the wrong marks. I saw the marks clearly and clearly lined up wrong marks. Once you do it once, you don't need any more light than the first time, you just know you've fricked up and won't do it again.
Timing on a KZ650 for example is so cut and dry, it's difficult to do a frickup, however on a KZ1000, yep, you've been bit by not carefuly lining up the marks as so many have been over the years.
- chconger
Re: timing f*** up
31 Mar 2015 09:46 - 31 Mar 2015 09:47
Its not 100% certain that you bent any valves. I misaligned mine this spring. Hand cranked, felt the bump, and found my error. No bent valves.
Check your valve clearances, if they are in spec your good.
1977 KZ 1000-A
Last edit: 31 Mar 2015 09:47 by chconger.
- jlat
Re: timing f*** up
31 Mar 2015 14:51 - 31 Mar 2015 16:19
hello people; Thanks for any advise and a friend was talking me into to one of those forehead lights but I never got one. I am gong for one. I hate shopping so were is the best place to get one?
Do many of you with the 1000 have both timing marks? It won't happen again and that's a lousy way to learn. But I never thought of the valves hitting each other as the marks on the intake V's could be that. A little hard to explain. I hand cracked it to many times so they might be bent. The rotation never got stuck but it felt like something pushing back. I had my thumb pushing in on the cam chain adjuster and it had force to cause some pain after a while.
Yes I F***ed up and it will have an end. I hope a good one.
IBBY
IBBY
Last edit: 31 Mar 2015 16:19 by jlat. Reason: wrong spelling
Re: timing f*** up
31 Mar 2015 15:08
