1978 kz400 points to electronic ignition swap.
- Jferr69
16 Mar 2015 18:07
I'm new to this forum and I've had many bikes over the years. I know much more about Yamaha viragos and Harley's. I'm wondering if anyone could point me in the right direction on how to upgrade the ignition from points to electronic. It was my girl's father's bike and that's what we think will help. Other than that the bike is in pretty great shape.
- kaw-a-holic
Re: 1978 kz400 points to electronic ignition swap.
16 Mar 2015 18:45
I was going to recommend a Dyna S but it looks Dyna Tech does't even offer the Dyna S for metric cruisers any more just the Dyna 3000.
here is their # if you want to call and see it a Dyna S will work, if so you can still buy them on eBay new and used.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- Nebr_Rex
16 Mar 2015 20:43
What does your spark look like?
Is it white or blue?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
17 Mar 2015 05:46 - 17 Mar 2015 05:48
I think you can use the electronic ignition from an 81-on KZ440.
needed parts: pulsing coil, timing advancer & ignition coil. I would get a new ign. coil.
The pulsing coil & ign coil from an 82-84 KZ750-Twin can also be used.
Aftermarket electronic ignition system: 7thgeardesigns.com .
kz400.createforumhosting.com --- 7thGearDesigns Electronic Ignition for '75 KZ400
The guy who came up with the ignition is known as KZJim on the various forums. Someone posted an installation topic which kinda indicated that the install was quite a bit of work, but it's possible improvements have been made since then (2008). Not sure if it's still available.
Last edit: 17 Mar 2015 05:48 by martin_csr.
- loudhvx
17 Mar 2015 08:12 - 17 Mar 2015 08:16
I think you can also use 1/2 of a Dyna S. I thought there were a few topics on that in the Kz400twins forum.
Using the Dyna S would require a Dyna S from another model, but I forget which one, possibly the one for the 550/650750. And the Dyna S ignition Rotor which should fit the stock advancer mechanism. You can use the old coil, but you will probably want to upgrade that to a new, 3-ohm coil. ("New" being the key word there.)
And if you just get a brand new set of points, that are good quality (many from China are terrible), you could use the points as a trigger for a GM igniter. That will eliminate wear at the points so they won't have to be adjusted for years (just cleaned by sliding a rag through them), and will allow you to use a more energetic coil. The igniter only costs about $20, and the other parts are a dollar or two.
home.comcast.net/~loudgpz/GPZweb/Ignitio...heiModForPoints.html
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 17 Mar 2015 08:16 by loudhvx.
