No exhaust gasket?
- New 750
No exhaust gasket?
16 Mar 2015 08:48
I finally pulled my 2-1 exhaust off to paint and there was no gaskets present where the pipes go into the head? Can I use just donut type automotive gasket? If so what is the diameter? I have held my hand there and never felt a leak, I just feel there should be gaskets in there. 1977 KZ750 twin, thanks much, Nate.
1977 kawasaki KZ750
Re: No exhaust gasket?
16 Mar 2015 09:12
They aren't too expensive. You can measure the pipe flange dia. but why not get new ones?
16 Mar 2015 11:13
The gaskets may be stuck inside the exhaust ports --- kinda common.
Z1Enterprises.com has the copper crush gaskets. There might be some fiber gaskets that will fit.
- bountyhunter
16 Mar 2015 15:01
The copper donut gaskets are what go there.
