84 gpz 1100 wat replacement fuel pump can I use
  • steve9755
  • steve9755's Avatar Topic Author
16 Mar 2015 04:47
#664567
Hey guys new here
I have 4 86 zx 1000rs one daily rider 3 in Wario us states lots of parts! If anyone needs anything
I just bought an 84 gpz 1100
barn find been sitting 10 yrs
very clean bike with 30 ks
So far it has good spark and compression
the fuel pump will attempt to turn but is siezed
if tried a heat gun tapping it and right now it's sitting full of penatrating fluid
wat are the pressure values fir this pump
and wat automotive pump can I use to replace it?
I want to keep the fuel injection system alive don't want to mess around with carbs
a y thoughts ?
Thanks
  • martin_csr
  • martin_csr's Avatar
Re: 84 gpz 1100 wat replacement fuel pump can I use
16 Mar 2015 05:23 - 16 Mar 2015 05:30
#664568
Walbro GSL393 is one possibility. not sure if there are others. don't know.
Goooogle search: site:kawasakimotorcycle.org/forum/vintage-motorcyle-info fuel pump
(finds only fuel pump topics in the Vintage section over there).
Here's a topic that mentions the Walbro.
kawasakimotorcycle.org --- Reply #10 ---Walbro GSL393: Reply #16: "BTW the Walbro is great!"
Last edit: 16 Mar 2015 05:30 by martin_csr.
  • riturbo
  • riturbo's Avatar
16 Mar 2015 07:50
#664593
martin_csr wrote: Walbro GSL393 is one possibility. not sure if there are others. don't know.
Yup thats the one all the turbo guys are using www.750turbo.com/forum/viewtopic.php?f=2...it=fuel+pump#p136935
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
