1981 kz1000j head vs 1981 gpz1100 head
- harleeblue
14 Mar 2015 11:15
does anybody know the differences between these two heads 1981 kz 1000j vs 1981gpz 1100j head????
bradley frantz
- ed spangler
- Tennessee Z
Re: 1981 kz1000j head vs 1981 gpz1100 head
14 Mar 2015 11:23
I would check with Larry Cavanaugh!
Cavanaugh racing Heads
Hes on this site ,maybe PM Larry?
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
- Nebr_Rex
14 Mar 2015 19:11
The 81 GPz1100 head has the injector bosses cast into the head.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
The following user(s) said Thank You: PLUMMEN, LarryC
- LarryC
14 Mar 2015 19:49
This is the head to have 83 GPz11
Attachment 10384584_1049944301688594_1609811578470180817_n.jpg not found
Larry C.
- harleeblue
14 Mar 2015 20:31
ok u got my attention whats done to it.looks ported and polished ,new valve guides, valves .
bradley frantz
- ChevyDK
Re: Re:1981 kz1000j head vs 1981 gpz1100 head
15 Mar 2015 23:45
I would also like to a bit about that head. What has been done too it. Are you selling and at what price? Best wishes from Denmark.
- Bozo
- Ride it like u stole it
21 Oct 2015 22:00LarryC wrote: This is the head to have 83 GPz11
I know this is an old post but.........
I have a "new" 1981 GPZ1100 motor (without the original head), I have two heads, one looks like a good condition Z1000J and the other is an 83 GPZ1100 (as seen in picture) but in a really bad state, it will require some welding etc. You stated that the 83 head is the one to use BUT the 81 GPZ has lower domes on the pistons so wouldn't that be counter productive if using this head (with std new pistons I have).
I know there is a difference in valve sizes (this is also my problem I need valves and guides for the 83 head).
Any comments to help me decide?? keep in mind the J head is ready to install and the 83 head requires valves guides and a lot of work.
- harleeblue
02 Jan 2016 04:09
I would use the bathtub head . But then you need the Pistons to match.i just put together a1981 1000j bottom end with a 1984zx 1100 jug and bathtub head. Runs good!!!
bradley frantz
- harleeblue
02 Jan 2016 04:24
I would use the head with bigger valves . if the bigger head is the bathtub head I would use that one!!!! Even tho the other head is ready to bolt on .
bradley frantz
