1982 kz550 fork seal
  • conman846
  • conman846's Avatar Topic Author
14 Mar 2015 10:43
#664395
I ordered what I thought was the correct size of fork seals from All Balls Racing. However, when i try to install them they won't budge.
The size I ordered was 36 X 48 X 10.5 mm
I'm guessing I need 1 mm smaller? so 35?
I can't find the size in my manual, if anyone can direct me to where I can find fork diameter sizes, it would be helpful.
Thanks.
Re: 1982 kz550 fork seal
14 Mar 2015 10:59 - 14 Mar 2015 11:03
#664396
Why not simply buy the genuine Kawasaki fork seals; then you'll know they will be the correct size. Forgive me, but I have difficulty understanding why folks go aftermarket for small parts that are still available; is there a reason? Ed
Last edit: 14 Mar 2015 11:03 by 650ed.
  • martin_csr
  • martin_csr's Avatar
14 Mar 2015 13:51 - 14 Mar 2015 15:28
#664414
Edit: What KZ550 is it?
36mm might be correct. not sure about the other dimensions, but the 10.5 might be wrong.
Made in Japan seals are preferable --- oem or K&L. The All-balls may be fine, but some aftermarket fork seals that are not made in Japan leak.
Edit: the 82 550H GPz fork seals are 35mm -->> from OhioCafeRacersForkTubeConversionChart
Last edit: 14 Mar 2015 15:28 by martin_csr.
  • missionkz
  • missionkz's Avatar
14 Mar 2015 14:39
#664420
Oh great.... I just got talked into buying and having shipped (they are here)
a set of All Balls 36mm-48mm-10.5mm seals for my 77" KZ1000. Is there a consensus that they are inferior...??
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
14 Mar 2015 14:52
#664425
I don't know if they are inferior; I installed All-Balls steering stem tapered roller bearings and they are great. However, if the seals are still available from Kawasaki that's what I would use simply because I would be positive they would be the correct fit and a good product. They may or may not be available for your bike; a dealer could check. Ed
  • martin_csr
14 Mar 2015 15:08 - 14 Mar 2015 15:17
#664430
Probably various reasons. No dealer nearby. Expensive dealer parts. Poor customer service for obsolete models. OEM fork seals are preferable, but it has been my experience that K&L parts are oem-quality, as their stuff is made in Japan.
Unfortunately, Z1Enterprises no long sells K&L fork seals. Instead they have k&s which are probably made in china. They switched fork seal brands because of price --- apparently, customers want a cheap price which gets them a cheap part.
Last edit: 14 Mar 2015 15:17 by martin_csr.
14 Mar 2015 15:21
#664433
If ordering online I guess aftermarket seals may be a few dollars cheaper, but considering that the original seals last 30 - 40 years I wouldn't think a couple dollars should be a show stopper. The odds are pretty good that they won't need to be replaced again for a very long time; if ever. Ed
  • martin_csr
14 Mar 2015 15:27
#664434
Another problem is that finding oem on-line might be difficult?
14 Mar 2015 16:18 - 14 Mar 2015 16:19
#664437
Maybe for some models, but it appears the KZ550 seals are still active. They were used on much later models. Ed
www.partzilla.com/parts/detail/kawasaki/KP-92049-1226.html
Last edit: 14 Mar 2015 16:19 by 650ed.
