Is a 80 kz shift spline the same as Gpz spline
- Todd smith
02 Mar 2015 18:13
I know this is a off the wall question but the splines on the shifter where it fits on the engine the same , my next quetion are all the splines the same on Kawasaki
- Todd smith
Re: Is a 80 kz shift spline the same as Gpz spline
02 Mar 2015 18:43 - 02 Mar 2015 18:44
My quetion is kz spline the same as gpz shifter spline
Last edit: 02 Mar 2015 18:44 by Todd smith.
02 Mar 2015 19:05
Could log in to Z1 Enterprises and search for a sprocket that fits both models.
02 Mar 2015 20:17
Patton,
Shifter spline is probably different from sprocket spline.
I wonder if the shafts have the same part number?
The following user(s) said Thank You: Patton
- zed1015
03 Mar 2015 07:19 - 03 Mar 2015 07:20
Yes! the gear change/shifter splines are the same on all z900/1000 and GPZ 1100.
Most Kawasaki's use the same spline.
Yamaha also use that same spline on some models R1/R6 etc but Suzuki tend to use a coarser spline .
Last edit: 03 Mar 2015 07:20 by zed1015.
- Todd smith
03 Mar 2015 16:19
Thanks you are correct that's a big help
- loudhvx
03 Mar 2015 16:40zed1015 wrote: Yes! the gear change/shifter splines are the same on all z900/1000 and GPZ 1100.
+1... have swapped shifters between Kz's and RD's in the past.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
