No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
Which gasket set ??
  • skooterbum4real
  • skooterbum4real's Avatar Topic Author
Which gasket set ??
01 Mar 2015 01:49 - 01 Mar 2015 01:51
#663022
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationI want to know which of these two gasket sets would be the best to use on my bike ......
Or........
Also is this a good oil seal kit ??
Thanks !!!
1978 KZ650B 8,500 miles
1976 KZ750 Twin
SPECIAL CONSTRUCTION V-TWIN CHOP
Last edit: 01 Mar 2015 01:51 by skooterbum4real. Reason: more info
  • bountyhunter
  • bountyhunter's Avatar
Re: Which gasket set ??
01 Mar 2015 12:11
#663078
Vesrah is the brand I have heard of and they have a decent reputation. The risk with ebay is you never know if it's been sitting on the shelf for 20 years. It may be fine, but you always take a chance that way.
I have no idea about the oil seals, same warning though.
The following user(s) said Thank You: skooterbum4real
  • bountyhunter
01 Mar 2015 12:13 - 01 Mar 2015 12:15
#663079
skooterbum4real wrote: I want to know which of these two gasket sets would be the best to use on my bike ......
Or........
Thanks !!!
NOTE:
Amazon sells the same Vesrah kit for $6 less and free shipping and their sellers are usually more reputable.
www.amazon.com/Vesrah-Complete-Gasket-Ki...ywords=gasket+VG-481
Last edit: 01 Mar 2015 12:15 by bountyhunter.
  • bluej58
  • bluej58's Avatar
01 Mar 2015 14:19 - 01 Mar 2015 14:20
#663090
I'm putting faith in Vesrah for my top end rebuild, they are made in Japan and I purchased the kit from Z1 enterprises.
But I am going to use an OEM O- ring for the cam chain tunnel even though the kit has an aftermarket one included.
JD
78 KZ1000 A2A
Last edit: 01 Mar 2015 14:20 by bluej58.
  • skooterbum4real
01 Mar 2015 22:08
#663137
Thanks for the input guys !!
Thanks for the link to Amazon bountyhunter !! I do all kinds of buying there...
I'll buy the Vesrah set from Amazon.
Anyone have suggestions about the oil seal kit ??
1976 KZ750 Twin
  • bountyhunter
02 Mar 2015 00:46
#663141
I don't have an alternate source for seals. By coincidence, the vendor selling those seals on ebay is RustyRiders LLC and I bought valves and shims for my 750 twin about 5 years back when I did my rebuild. I had good luck with that vendor, all the parts were 100% good. So at least that is good news.
  • Nessism
  • Nessism's Avatar
02 Mar 2015 05:31
#663151
I'd pass on Vesrah and get real OEM Kawasaki gaskets. Lots of guys on the GS Resources site have had issues with leaking base gaskets using Vesrah. The cost savings isn't great enough to justify the risk and durability issues.
  • bountyhunter
02 Mar 2015 12:48
#663209
Nessism wrote: I'd pass on Vesrah and get real OEM Kawasaki gaskets. Lots of guys on the GS Resources site have had issues with leaking base gaskets using Vesrah. The cost savings isn't great enough to justify the risk and durability issues.
The base gasket from my Athena set failed so I made one using the Auto Zone gasket material. Worked very well.
  • zukdave
  • zukdave's Avatar
02 Mar 2015 16:00
#663225
I've got the Vesrah kit in my motor and have NEVER had a leak.
I've had the clutch cover off about five or six time's and it still does not leak.
I think most leak's are from the install not the gasket's themself.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • Nessism
  • Nessism's Avatar
02 Mar 2015 16:03 - 02 Mar 2015 16:04
#663226
zukdave wrote: I've got the Vesrah kit in my motor and have NEVER had a leak.
Did this Athena base gasket fail because I installed it wrong?
Use Vesrah if you want. I'd rather spend a little more for OEM.
[IMG
[IMG
[IMG
Last edit: 02 Mar 2015 16:04 by Nessism.
  • bountyhunter
02 Mar 2015 21:53 - 02 Mar 2015 21:55
#663268
[IMG
[IMG
[IMG
Looks exactly like the Athena gaskets that failed on my rebuild, except mine was on a 750 twin. The green colored gaskets all failed once they got hot. They got brittle and disintegrated into bits and it only took a few days. Base gasket and oil pan were the most obvious because the pieces were falling out. I don't know what material that green stuff is, but it's useless.
I agree OEM are better if you can find them, but the material I got at Auto Zone worked great for the ones I couldn't like the base gasket and oil pan.
Last edit: 02 Mar 2015 21:55 by bountyhunter.
  • bluej58
  • bluej58's Avatar
03 Mar 2015 05:12
#663281
Thankfully no green gaskets in my Vesrah kit, :blink:
78 KZ1000 A2A
