andrews 2x exhaust cams
  • Cal
  • Cal's Avatar Topic Author
25 Feb 2015 01:08
#662705
Greetings fellow kz lovers,could you please answer a question for me,I've got 2 andrews 2x exhaust cams with the tach drive,can they both be used in the same engine ?? Thank you very much,,ride safe my friends
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: andrews 2x exhaust cams
25 Feb 2015 05:53
#662710
The lift and duration are the same but the timing is different. If you can work that out, I'd say yes. How did you get two of the same? Ebay?
  • Cal
25 Feb 2015 06:11
#662714
Yes,thanks for the reply,,so I can't just drop it in,that sucks,,,ac tally I was gonna bid on another one,,but I guess I won't bid on it
  • SWest
  • SWest's Avatar
  • 10 22 2014
25 Feb 2015 06:14
#662715
I just sent you a PM. If you just bought them, you can file a not as described case and get your money back. That is if it's been less than 180 days.
  • SWest
  • SWest's Avatar
  • 10 22 2014
25 Feb 2015 06:15
#662716
I'm going to look it up.
  • Gman
  • Gman's Avatar
28 Feb 2015 08:27
#662969
If these are for the '73 - '80 Z1900 - KZ1000 generation engine, I believe they are the same. You should be able to use them on intake or exhaust side.
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
  • Cal
28 Feb 2015 15:12
#662999
Thank you very much
