Ignition rotor
  • ricko1966
  • ricko1966's Avatar Topic Author
Ignition rotor
21 Feb 2015 21:32
#662323
Hello it is my first post,brand new to kz need some help I bought four basket cases hoping to build 2 bikes the ltd 750/4 is missing the ignition rotor and hardware advancer is there pickup coils are there nothing else will the pieces out of the csr 650 work?
  • martin_csr
  • martin_csr's Avatar
Re: Ignition rotor
22 Feb 2015 07:41
#662356
Not sure what part is needed.
Most of the 650-CSR ignition components are the same, except the timing advancer.
The following user(s) said Thank You: ricko1966
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: Ignition rotor
22 Feb 2015 12:26
#662384
check out the part number, some bits get used in quite a few models.
As a guess, I'd think most 650 750 electronic ignition parts would be interchangeable.
  • martin_csr
Re: Ignition rotor
22 Feb 2015 14:23
#662401
That's correct. They have the same igniter, pulsing coil & ignition coils.
The CSR timing advancer has a different part number --- I would assume its advance curve is different.
  • ricko1966
Re: Ignition rotor
22 Feb 2015 18:15
#662429
The advancer is still there the plate withe the pickup coils is there but there is nothing between the advancer and the pickup coils I didn't want to start pulling stuff of the 650 motor if it wasn't going to fit but if the rotors spacers and misc hardware is the same it looks like the 750 should run this weekend.Thanks
