First start, running better
  • 123vucku
  • 123vucku's Avatar
Re: Rough running after first start
20 Feb 2015 15:08
#662168
Also make sure u have no rips or tears In them
  • jsnabbs
  • jsnabbs's Avatar Topic Author
  • 1981 kawiKZ440
Re: Rough running after first start, running better
24 Feb 2015 09:17
#662588
Ok so i had another shot at today and it seems to be going better.
The pipe off the lefthand side is a breather pipe, so i put a hose on it and run it out the back. (as mine is a KZ440C the carb is a little different
The tapping sound seems to be alot better
The problem with the high RPM's was an amateur mistake, i had the throttle stop screw wide open.
since this is my first build im super nevious about every little thing.
1 the pipes got some color on them very fast, is this normal ( is there a "right" color for them to change to? or a color to look out for?)
Attachment IMG_1337.jpg not found
2 there was a little bit of white smoke coming out the muffler, is this ok?
sorry for all the questions, its a bit nerve racking for me
TIME TO TRADE IN THE PEDALS FOR SOME POWER
