gears not engaging
  • Robx
  • Robx's Avatar Topic Author
gears not engaging
14 Feb 2015 19:18
#661643
I have a KZ1000 1A 1977. Electric start works, kick start doesn't. Can't seem to engage any of the gears. What's my problem?
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Re:gears not engaging
14 Feb 2015 19:31
#661645
Kick start will only work with the clutch lever released since the gears engage with the clutch basket.
Kawasaki also has a "positive neutral finder". That means only neutral or 1st gear can be selected unless the rear wheel is spinning some.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Robx
14 Feb 2015 22:34
#661661
My fault I let the lever have lots of slack thinking that would work as yest but took cover off and adjusted all good thanks very much for reply.
  • Robx
Re: gears not engaging
14 Feb 2015 22:40
#661662
The first gear neutral was very helpfull as well cheers
