Clutch issues
  • Skiprrdog
  • Skiprrdog's Avatar Topic Author
  • "Are we there yet?"
Clutch issues
09 Feb 2015 13:47
#661061
Dang, I must have offended the motorcycle gods or something, no sooner do I successfully do my first set of fork seals this past weekend, and now this. I searched to forum on clutch issues, but nothing seemed like what I am experiencing.
I noticed yesterday when I took it for a short test ride, that when started it and put it in first gear, that it seemed to want to creep forward a little bit. So per my manual, at the grip and the barrel adjustment in front of the motor, I turned the adjusters all the way in. Then I took off the little inspection cover for the release mechanism and adjusted that, and finally adjusted the cable for 1/8" play at the grip. Started the motor, put it in gear and it still wanted to creep forward, except now when I let the lever out, nothing.
It is a 1996 KZ1000P and I am running the Rotella T oil in it.
HELP!!
1983 KZ1100 A-3 Shaft
1976 KZ900
1975 H2 Triple
1984 Yamaha XJ900 Seca
1984 Harley Davidson FXRDG
#BlackBikesMatter
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
Re: Clutch issues
09 Feb 2015 14:05 - 09 Feb 2015 14:07
#661064
You say "I start her up"... what happens when things are warm? Give her a min or two, to get some heat... then see how things feel/react. Let us know...
OH... and you should not even be finger tight, against the clutch rod. Heat expands...
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
Last edit: 09 Feb 2015 14:07 by !Seymore.
  • Skiprrdog
Re: Clutch issues
09 Feb 2015 14:24
#661066
Okay, I let her get good and warm, same thing. Pull in clutch, shift into gear, and it still wants to lurch forward momentarily, then stops. Here is a new thing I noticed though, I let the clutch all the way out while in gear, no movement or obvious load on the motor, but then it dies...it did this every time I tried it.
What do you mean by finger tight against the clutch rod?
1976 KZ900
1975 H2 Triple
#BlackBikesMatter
Re: Clutch issues
09 Feb 2015 14:43 - 09 Feb 2015 19:32
#661068
Skiprrdog wrote: ...took off the little inspection cover for the release mechanism and adjusted that....
Instructions in the manual may be confusing or just plain wrong.
Try the clutch push-rod adjustment again, but this time turn the adjusting screw the opposite way until it stops, then turn it the other way 1/2 turn before tightening the locknut.
Good Fortune! :)
Last edit: 09 Feb 2015 19:32 by Patton.
  • Skiprrdog
Re: Clutch issues
09 Feb 2015 18:23 - 09 Feb 2015 18:23
#661097
Thanks Patton; after I posted a second reply here, I did just that, turned it all the way to the right until it stopped, and then back a little bit CCW and Voila! I have forward motion again. My KZP rebuild...always an adventure. Thanks again for the reply.
1976 KZ900
1975 H2 Triple
#BlackBikesMatter
Last edit: 09 Feb 2015 18:23 by Skiprrdog.
  • Skiprrdog
Re: Clutch issues
10 Feb 2015 18:06
#661183
Well, I guess the fix i thought i had for my clutch problem yesterday was too good to be true.
I went to move the bike into my garage this morning, pulled in the clutch to start it, and the lever went completely slack on me. Pushed it into the garage, took the clutch release cover off thinking I would check the adjustment, and I cannot turn that slotted adjuster either way.
Where do I go from here? I have a Clymer manual, but it has scant information on this.
1976 KZ900
1975 H2 Triple
#BlackBikesMatter
  • F1schumie
  • F1schumie's Avatar
Re: Clutch issues
11 Feb 2015 23:48
#661369
ahhh KZs
always have a few clutch cables and tach cables at hand... They always snap if u ride a lot or snap gears on shifts..
engine oil and clutch springs are key.. even today in a pinch I will top off with car oil an it bites my azz eventually..
also your angle and dial adjustment for clutch cable is key.. newer levers put a pre angle tention spot on cables and the biggest pooper is the slot for the cable..
if not right it runs on edge and super quick it cuts through cable strands and then no matter how much adjustment you do the cable has no strength left..
also your carb spring set up for return and on power if proper.. you want to here that snap when you twist the throttle when parked and off..
J
  • Skiprrdog
Re: Clutch issues
12 Feb 2015 05:41
#661380
Yeah, I already ordered a clutch cable for it, it is (up to)19 years old, so I figure its probably time :P
Whatever is wrong with the clutch (I am guessing the release mech) I have no clue, though. Guess Ill just start taking her apart and see where that goes...
1976 KZ900
1975 H2 Triple
#BlackBikesMatter
  • whirlwind598
  • whirlwind598's Avatar
Re: Re:Clutch issues
23 Feb 2015 21:51
#662557
Skiprrdog wrote: Yeah, I already ordered a clutch cable for it, it is (up to)19 years old, so I figure its probably time :P
Could you upload some pictures?
Unless you already figured it out.
