dead cylinder 4 any suggestions
  • 123vucku
  • 123vucku's Avatar Topic Author
Re: dead cylinder 4 any suggestions
03 Feb 2015 18:12
#660529
Checked valve clearances for the valves on cylinder 4... intake is .15mm and exhaust was .8mm...... .15 is out of spec due to my manual but people on here have said it was later updated and that it's acceptable ...?
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Feb 2015 21:33 - 03 Feb 2015 21:34
#660546
What abut the float level test? thought you said you did a compression test..
Last edit: 03 Feb 2015 21:34 by SWest.
  • 123vucku
04 Feb 2015 03:47
#660559
I haven't been able to do the float level one and yeah I've done a compression test . I was asking if my intake valve being .15mm is okay?
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Feb 2015 05:46
#660565
If that carb is starving for fuel you will get nowhere. What are the reading in the compression test? .15 is the limit on clearance.
  • 123vucku
04 Feb 2015 06:46
#660574
150 cold with open throttle no oil added
  • 123vucku
04 Feb 2015 06:49
#660575
Yes I know ...haven't started yet or anything until I check the level I'm gonna make a stand for the carbs
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Feb 2015 07:14
#660582
I just hang them up with a wire.
  • 123vucku
04 Feb 2015 07:15
#660583
They gotta be perfectly level right?
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Feb 2015 07:24
#660587
Should be level. You can make a small fuel tank out of a plastic water bottle to hang above it. Drill a hole in the bottom small enough so the hose is tight. Loosen the cap, fuel flows, tighten it, it stops. simple.
  • 123vucku
05 Feb 2015 14:13
#660712
It was just as I suspected the leak from the intake boot was the problem... replaced them and cylinder is back In action thanks everyone definitely helped me solve my problem
  • TexasKZ
  • TexasKZ's Avatar
05 Feb 2015 17:26
#660727
By the way,beautiful H2, man.
Tripleted wrote: Get the bike running( on the cylinders that it does run on) and then spray WD 40 into the non running carb. If it is a fuel problem the cylinder will fire up and the pipe will warm up at the exhaust flange. Take the float bowl off and see if there is fuel in it. Turn the fuel on and see if the fuel pours out with the bowl off. Take the carbs off and clean them the right way and use WD40 with the red spray tube attached to the nozzle to spray into every hole and make sure you have all air and fuel passages clear. Having said all that, it is probably either a clogged pilot jet or clogged float valve.
Attachment ipadpics168.jpg not found
