'77 Kz650c Potential Valve Issues
- rage_rides
18 Jan 2015 19:56
Hey, this is my first post. This is a rad community and I'm stoked to be a part of it!
I've got a 1977 KZ650C chop. It ran fast and loud before I started having some issues a few weeks ago. One day I started it up and after a brief warm up and ride it felt like it was running poorly and wouldn't stay running at an idle. I parked it at home and let it sit. It was just after dark and while trying to get it to run again I realized it wasn't firing correctly on the number 3 cylinder. The exhaust tube coming from number 3 wasn't cold, however, it was searing hot. If I gave it some throttle (while running) it would smell like hot and the pipe itself started glowing a dull orange. I immediately turned the bike off. I cleaned the carbs, jets, float needles, made sure floats were adjusted correctly, etc. The problem has persisted though and I won't let the bike run for more than needed to try out little fixes.
Does this sound like a stuck valve on the exhaust side of cylinder 3? If not, what should I look at next? If it is, should I remove the cylinder heads and start there? I have the Clymer manual and have taken the bike apart a few times, but I don't want to get into the block before I get a second opinion.
I appreciate any help.
Attachment CAM00118.jpg not found
- !Seymore
- Ride on...
Re: '77 Kz650c Potential Valve Issues
18 Jan 2015 20:00 - 18 Jan 2015 20:01
Welcome. If you have a stuck/bad valve,... have you run a compression check?
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
Last edit: 18 Jan 2015 20:01 by !Seymore.
18 Jan 2015 20:02 - 18 Jan 2015 20:03
Glowing red exhaust pipes are NOT good. Not sure what to suggest other than the basics like making sure the carbs are clean, no intake boot leaks, the choke isn't sticking open, and adjust the valves. Valves rarely stick, but a lot of people don't adjust them which causes them to burn.
Last edit: 18 Jan 2015 20:03 by Nessism.
The following user(s) said Thank You: PLUMMEN
- rage_rides
18 Jan 2015 20:06 - 18 Jan 2015 20:07
I haven't run a compression check. Should I? And what would poor compression indicate for the situation? And I haven't done a valve adjustment since I've owned the bike, I should probably take a look at that.
Last edit: 18 Jan 2015 20:07 by rage_rides. Reason: Replies
18 Jan 2015 20:28 - 18 Jan 2015 20:32
If not already done, would also inspect and assure serviceable condition and proper functioning of the ignition timer advancer unit, especially that the weight arms move freely on their pivots.
The advancer might be rusted and stuck in position, or the pivots might simply need lubing.
The advancer isn't supposed to look like this:
Where lubing is desired, may sometimes reach the pivots through the timing inspection window (without needing to remove the points plate in order to gain full access to the entire advancer).
Last edit: 18 Jan 2015 20:32 by Patton.
The following user(s) said Thank You: rage_rides
- !Seymore
- Ride on...
18 Jan 2015 21:23 - 18 Jan 2015 21:24rage_rides wrote: I haven't run a compression check. Should I? And what would poor compression indicate for the situation? And I haven't done a valve adjustment since I've owned the bike, I should probably take a look at that.
Could mean a valve adjustment or other compression leak problems... let us know what you have here, before tearing into the engine. Helps to diag the problem before tearing in and not knowing some baseline.
C.
Last edit: 18 Jan 2015 21:24 by !Seymore.
18 Jan 2015 22:01rage_rides wrote: Hey, this is my first post. This is a rad community and I'm stoked to be a part of it!
WTF is that?
- PLUMMEN
18 Jan 2015 22:05
Id tear back into the carbs again if it just started getting hot all the sudden on one cylinder,maybe try swapping a different set of carbs on there just to see if it makes a difference.
19 Jan 2015 06:15
Could perform a quickie clear-tube test on #3 carb to rule out possible fuel starvation due to a too low fuel level being caused by whatever reason.
- bountyhunter
19 Jan 2015 12:48That the valve is not fully closing or is not seating well.rage_rides wrote: I haven't run a compression check. Should I? And what would poor compression indicate for the situation?.
- rage_rides
19 Jan 2015 15:21
Thanks for the help guys, I've got some good places to start. I'll hit it this week and let you guys know how it turns out.
- !Seymore
- Ride on...
19 Jan 2015 15:31bountyhunter wrote:That the valve is not fully closing or is not seating well.rage_rides wrote: I haven't run a compression check. Should I? And what would poor compression indicate for the situation?.
...or rings that are no longer sealing. But a leakdown test helps, in this regard.
Yes RR, please do keep us posted with what you discover.
C.
