o ring dimensions
- Markgrff17
o ring dimensions
18 Jan 2015 07:27
hi everyone
I'm finally getting around to re assembly my 1983 kz550 A3 and could do with a little advice on some o-ring dimensions.
to refit the sump I need 3 o-ring for the oil ways which look to measure 13 x 4 and 1 for the oil filter chamber at 88 x 4. I have no old O-rings to measure so these measurements are taken from the fitment areas.
does anyone the correct dimensions?
many thanks in advance mark
- Markgrff17
Re: o ring dimensions
19 Jan 2015 10:59
Hi again
If no one can help with dimensions where could I find the Kawasaki part numbers and if these o rings are still available.
Thanks in advance. Mark
19 Jan 2015 11:44
Partzilla.com
or PowerSportsWarehouse. Partzilla is easier to use.
I think the diagrams will list the size or ID of some of the o-rings.
The following user(s) said Thank You: Markgrff17
- !Seymore
- Ride on...
19 Jan 2015 11:51
Mark... you you still have the unit out, why not take it to your local auto parts store and see what they have in the way of O-rings to fit the areas you need filled? Yea, I know it's ol'school, but IMPO this is the best way to assure you get what's needed, without guessing and hoping. You may even find a good human willing to assist. Most of these ol'school guys know what you're going thru and are more than willing to help.
I needed, in short order, an O-ring for the base of a petcock. It took me ~1hr, <$1 and I had what I needed.
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
- Markgrff17
19 Jan 2015 13:21
Thanks for your replies
Think I've found the parts numbers from partzilla
671B2590
92055-077
Just wondering if anyone knows the Iinternal dia and c/s diameter. I have access to large range of o rings but need to be sure I get these right.
Thanks again. Mark
671B2590
92055-077
Thanks again. Mark
