'92 KZ 1000 Police won't start
06 Jul 2006 13:26 #59693 by rhino642zz
'92 KZ 1000 Police won't start was created by rhino642zz
I replaced all the gaskets in my engine, put it all back together, checked the fuel, plugs, and wires but the beast won't start. The crank turns but that's it. Any suggestions?
Dal
06 Jul 2006 14:14 #59707 by trippivot
Replied by trippivot on topic '92 KZ 1000 Police won't start
cams out of alignment ?? timed ignition in time? everything plugged in? valve adjustment right?
06 Jul 2006 15:13 #59720 by rhino642zz
Replied by rhino642zz on topic '92 KZ 1000 Police won't start
How do you check the above items?
07 Jul 2006 05:24 #59865 by trippivot
1. what gaskets did you change?
2. did the bike run before you started working on it?
3. undo what you did
4. buy a manual, it will be a valuable resource
